hiya
i have same light problem same your..hv u sort out yet? let me know if u know what the problem cheers
Tony, there is no MAP or MAF sensor on the 1.4 12valve. It uses engine RPM, Throttle anlge and water temperature sensors during acceleration. Probably one of the reasons why its not great on fuel for its size 1370cc.First thing to do is check that the cam belt has not jumped a notch or two.
If all ok try changing the MAP sensor.
Either the vacuum is low or the ecu thinks the vacuum is low.
Tony.
Oops! thats not even in my reference.
Tony.
