Hi there,
I am really two minded at the moment, as to put a 1242 engine in my 899 or buy another 1.1 and swap it that way. So i am hoping to get some pros and cons from you guys .
Well here is my thought
The things that they both have in common:
Same wiring loom, bolt to bolt swap, .
for the 899:
Needing new engine mounts, and may be ecu changed ? Also i heard to a little bit harder of a job and i take i will also need the gear box + the dials from the sporting.
But the car is lighter, and does not have sunroof may imply a stronger chassis ?
for the 1.1:
Easy job, same engine mount and a closer ratio gear box (so shall that need change ?)
Well the car is that little heavier ^^.
most of the information was gather here,
https://www.fiatforum.com/cinq-sei-technical/22060-cento-engine-swaps.html
so i did read the thread. i just wanna see what route would u guys take and how much do the 1242 + gear box usually cost ?
thanks thanks
for the 899:
for the 1.1:
thanks thanks
