Technical 105 JTD - Where is Throttle Body / Throttle Potential Sensor
Pontefract W.Yorks
I still think I have a performance issue and there are definate flat spots, its like I can get max performance with half throttle pedal action, pushing any further doesnt seem to make much difference.
So wanted to give this sensor contacts a clean. It worked for my coop but that time the injector light came on and diags pointed to the TPS, this time in the Marae , no injector light so its a long shot, costs nottin to try :D
I mean Position Sensor . What was I thinking although it can make sense.
OP
OP
b1gduk
Pontefract W.Yorks
It could be that but I had the MAF out of its casing tonight and gave it a clean with alcohol. Looks like new now. What is there to go wrong ? I peice of wire that gets dirty ?
hmmm. I did the reset on the ECU afterwards and let the car idle for 5 mins as per the BOO instructions. Didnt seem to make much difference but then when I unplugged it that didnt either so it may not the the MAF at fault.
So back to the question ? Where is the Throttle body , where I can rev the engine without sitting in the car, the TPS is usually around there if there is one.
Cheers:worship:
