The100hpGuy
- Joined
- Sep 22, 2014
- Messages
- 43
- Points
- 16
This is a strange one... Heat decides to only come out of the vents when the fan speed is put up to max (after hearing a clonk) and then you are able to lower the fan speed... But then if you go too low on the fan speed you hear another clonk to which only cold air comes out... All of this doesn't matter what temperature you set it, it's either cold on a low speed or hot when the speed is put up to maximum (even when the air con is switched on).
Have no idea what it could be, any ideas?
