Matt_Dawtry
I have a Fiat Punto 1.1 SX with a heater problem ... only the third speed works on it (speeds 1 and 2 do nothing).
I recently changed the battery and since then the heater only works on speed 3 - I'm not sure if the two are related or just a coincidence.
I've checked all connections around the battery and all seem intact and connected as before. The heater "nob" is also in as good condition as previously (checked it just in case and found nothing untoward).
Any other points to check that could be causing this?
