The rear wishbone mounts are similar in many ways to the swing arm mounts on a motorcycle. Some bikes like the SV650 for example have ride height adjustable swing arms to accommodate more petite riders. That would be a complicated thing to try to apply here. However at the other end of the swing arm is the chain adjusters. The wheel pin goes through these and can be adjusted back a forth to allow the chain to stretch in time. If these were mounted perpendicular on the outside of a Punto subframe with longer wishbone pins it would allow adjustment of the wishbone mounting angle and therefore provide camber adjustment.
What do we think?
Or the eccentric style motorcycle chain adjusters.
Problem, I suspect, is that the semi trailing arm bushes are a a pair which might mean that the bolts are put through a big, big, bending load at some points. (I'm sure this would be the case with the Cento set up -- where too much begative becomes an issue on dropped cars -- but have never looked seriously at a Mk1).
