My 1.6 Bravo 1997 has started to overheat because the radiator fan is not coming on. I bought a new radiator cooling fan switch and this solved the problem for a few days then the fan would not come on again. I then re-newed the coolant. I scwred the two bleed screws off and filled the coolant until the cooland came out the bleed holes. I then screwed them up. Everything was fine until a fews later the fan would not come on again. Could this be becasue I did not run the engine when I was trying to bleed the system?
