Technical 1.4 16v Super Fire Engine Which Models
Wellingborough
Hi guys, thinking about buying a 1.4 16v Lump for my seicento, (y) D4NS ur fault! lol
Which models do they feature am i right in thinking :
  • Punto MK1 95
  • Stilo 1.4 16v
  • Grande Punto 1.4 16v
  • Panda 100hp
Any others? also can i still run the 5 speed box?
Thanks Andrew
There are others as well, Idea etc. Just look for any 1368cc 16v without the variable exhaust cam (starJET). These ones are spotted easily as they have an extra oil switch/solenoid, on top of the head. It's not a biggie though, but will make it a pain if you go with aftermarket cams etc. Also the intake is different (studding etc) so older inlets won't fit and the intake ports will need some modding.
Krsitian
The inlet from a mk1 punto 1.2 16v is what you mean, as it's easier option as you can bolt a cable throttlebody on happy days.
The newer 1.2 and 1.4 for manifold has fly by wire bodies and are a different bolt pattern so cable bodies won't fit on unless you make an adaptor plate.
Another thing to consider is the 1.4 engines are COP rather than coil pack, so you will need a coil pack mount plate from a mk1 punto or early mk2 (y).
X
so if i got a stilo engine would i need the adaptor plate? to fit the 1.2 16v Inlet?
is it possible to stick with COP or should i just go for the mount ?
X
Plan is to keep it as close to as fiat would have done it from the factory...lol
issue with that is how do u modify Pedals etc....
Btw anyone fancy bankrolling this ?
[ame="http://cgi.ebay.co.uk/Fiat-500-Abarth-1-4-Turbo-Engine-2009-/360339652677?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53e5eac045"]Fiat 500 Abarth 1.4 Turbo Engine 2009 on eBay (end time 26-Feb-11 16:30:29 GMT)[/ame]
