1.2 punto active 2005 wont start.
DaveHoughton
Hi and help!
My car wont fire on start up.
The fuel pressure relief valve is spurting when pushed, so guessing its not pump or filter.
It was starting after a few goes, and then running fine until revs dropped to 1200rpm, when it died again.
Now wont fire at all.
Any ideas?
Update
Just tried easy start and still no joy.
Does this point to electrical?
Checked some earth points. Not checked timing yet. I'll try that next.
Just made things worse though! Went through all the elecrical plugs to clean them. Now fuel pump wont run. Checked fuse and relay. They seem ok.
Put a new crankshaft sensor in. Sorted fuel pump relay.
Car started and stalled after a couple minutes.
Turns and tries to fire now, but wont idle if it does go.
Any ideas?
