1.2 litre Multijet Diesel Fault Code PO160
RJX13
1.3 litre Multijet Diesel Fault Code PO160
My 1.3litre diesel multijet Idea has developed an engine failure, the fault code is PO160. Has anyone any experience of what this code is and how it can be rectified?
a1ant
-~Moderator~-
Staff member
UK
Ox sensor circuit no activity detected - sounds like your lambada has become disconnected possibly?
a1ant
-~Moderator~-
Staff member
UK
And...Wlecome to the Fiat Forum!!
Liam
hi friends :waves:
Scotland
Is the fault because it has lost 100cc of capacity?
It's a 1.3 diesel.
Liam
OP
OP
R
RJX13
48cc to be precise. Yes I should have called it the 1.3 litre multijet. The actual engine displacement is 1248 hence my mistake.
B.
OP
OP
R
RJX13
The car is a FIAT IDEA, though I guess it is the same 1.3 multijet diesel engine that is used in the Punto and Panda.
B.
jug
blessed are the apostates
Durham
the fault code is P0160, not PO160, you shuold have got a small booklet with your codereader that explans all the codes, however there are plenty of places online that tell you generic and manufacturer specific fault code meanings.
P0160 is on this list: http://www.elprog.com/download/Auto_dijagnostika_programi/OBD2_kodovi/obdcodes.pdf
it says:
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
this tells you that it is your second (aka downstram) lambda sensor that has no signal at all. usually that means it is comepltey dead or there is a wiring fault.
a1ant's suggestion that the wiring connector may be the problem is also my first thought. if in doubt change the lambda, but make sure you change the right one.
