Technical " 1.2 8v gearboxes, different gear selectors? HELP
meggs88
Hi, my 2004 1.2 8v punto has a cracked gearbox casing, bought a 2nd hand one off a 2002 1.2 8v and the gear selectors on top of the gearbox are different.
Does anybody know if these can just be swapped over from my old gearbox without any issue?
Chris
Chris
some of the arms were different, can you put some pictures up. if the box is the same you may be able to just swap over the selector casing over or may not have to do anything
Its definitely off a mk2, 2002 model. The actual housing is the same, and so are the shaft no's.
Here are the part numbers the garage took off the gearboxes. Above the line is the gearbox on the car, below is the "new" one.
Thanks guys, gearbox is fitted and everything lined up without changing gear selector over.
