Technical 07 Auto Transmission Problems... Please Help!!
fiatpunto1991
Hello everyone,
i am completely new on here and no naff all about cars so i am after some advice. I bought a automatic fiat punto 07 reg last year and it has been great. Recently though, usually when starting the car, it will not go into gear. It just stays in neutral and beeps constantly saying 'Gear Unavailable' 'Check Transmission'. Turning it on and off numerous times helps but obviously this is not healthy to keep doing.
Any ideas??
thanks
Ben
i frankly have no idea but as its a fiat its quite likely an earthing issue
i had a similar problem with the previous model and only removing the rear lights and cleaning up the brake light bulb pips caused a cure
reason being you cover the brake as you move transmission and this was causing the gearbox failure
you couldnt make it up:D
No, i am sure i don't have a Grande punto?
Thanks for your advice though... what are brake pips?
ok and what do i need to check with this? Or do you mean it will need replacing?
Thanks for your help!!
