Technical '06 Panda crank sensor issue.....
No that network should end on pin 11 and 12 on connector D of the BCM
If the diagrams are to believed
This is the none 4x4, post 2008, dualogic, 1.2 and pre euro 5
This one has ESP yaw sensor k074
These are all the bcm connectors not sure if they do appear all of them
That's the one and OL with the ABS connected
It's ok but everything is plugged so all control modules except the bcm are connected
So this network we were testing contains what or better yet which modules?
I was surfing around the web about possible issues i got that the EPS might cause this now I'd like to add that i once dismantled the steering angle sensor and repaired it as it was very expensive and the car ran fine ever since is it possible that the steering angle sensor is related to the canbus and has failed resulting in this?
