Old 19-03-2007   #1
Mexico
Question Head lights high beam.. help
Does any body know how to lateral align them or is it a dealer must job?
http://img407.imageshack.us/img407/9811/michaelgf3tz3hz3.jpg PERMAGRIM CLUB
Athos is offline Reply With Quote Quote
Old 19-03-2007   #2
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
Re: Head lights high beam.. help
I've been through this with mine and discovered nobody knows how to adjust them.
Take it to a good dealer.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 20-03-2007   #3
Mexico
Quote Originally Posted by Argonought View Post
I found a picture that shows an adjustable screw this one will allow to modify lateral alignment but maybe you have to take the bumper out:
The one marked with the number 6.
Old 21-03-2007   #4
Argonought's Avatar
Well spotted That and the regular plastic adjuster should provide full alignment.
But why do you want to adjust them?
On mine it turned out to be nothing more than a badly seated bulb
Old 21-03-2007   #5
Mexico
Mine is spoted trough incoming trafic!
And one is high and the other low, I will align them this weekend, but havent found yet how to align vertically other than dash button.
Old 24-03-2007   #6
I adjusted mine both vertically and horizontally, it's simple
If you look behind the headlamp you will see two white pins sticking out, one behind the high beam and one behind the low beam. If you want to adjust the vertical alignment, you will need to turn the pin behind the low beam with a small spanner clockwise for up and anti-clock wise for down. To adjust the Horizontal alignment turn the pin behind the high beam in the same direction as you want to go.
You need to set the car on an even surface about 20ft from a wall. Done mine myself and there perfect now
Some times it will look like the beam isnít moving but, trust me, it is!
CaRcAzY
Black Mazda 3 MPS: Sunroof, Cruise & climate control Rain, light & parking senors, Bucket leather seats, Navigation system with PS2 & DVD, Xenons, Bose Hi fi System, mazdaspeed Induction kit, now running 275bhp, Sports Areo Kit with 18" alloy wheels !!!!!TOTAL MADNESS!!!!!
carcazy is offline Reply With Quote Quote
Old 24-03-2007   #7
ChrisMClark has donated!
What do you align it to on the wall? The bottom where it meets the ground?
2007 GP 1.4 8v Dynamic Sport daily
2004 Alfa 147 2.0 TS project
And a history of Mk1 Punto and 2 Stilos.
ChrisMClark is offline Reply With Quote Quote
Old 25-03-2007   #8
Mexico
Quote Originally Posted by carcazy View Post
CaRcAzY
Thanks CaRcAzY, I have saw only one white stick, but the other must be there also unles they take it out in the '07 series, I will align them this sunday.
Old 25-03-2007   #9
Argonought's Avatar
Question Re: Head lights high beam.. help
That's a very interesting post.
So you're saying you track BOTH dipped AND main beam together
Presumably there must also be some adjustment to change main beam relative to dipped or is this simply not possible
Old 25-03-2007   #10
Both the lights are aimed to gether.
CaRcAzY
Old 25-03-2007   #11
Quote Originally Posted by ChrisMClark View Post
Hope this helps.
CaRcAzY
Old 25-03-2007   #12
It does indeed, thanks very much
(T) Head Gasket Repair / replacement!!! derekmcluckie Punto (Mk2/2b) 8 02-08-2006 13:39
(T) After fitting a Head Gasket andyr Punto (Mk1) 16 17-04-2006 18:48
(G) High level Brake lights adjessop Bravo / Brava 4 04-04-2006 21:51
(G) Xeon head lights Paul Westhead Stilo 23 06-04-2005 06:25
