ScottyP said:
I never topped up the oil from one service to the other in the Alfa and that was a much more powerful engine.
Well I don't top up my oil, but that's because my car's purple
Seriously though, engine power has nothing to do with it, it's more likely to be connected with how the engine was run-in, how the engine's driven now, whether the engine's reaching full operating temperature, and also apparently whether or not it's a Vauxhall (Argonaught - I agree!
Some of you guys are doing relatively high mileages per year (well, compared to the 10,000km or so that's common here) and so I think the need to top-up the engine oil is unavoidable. If it didn't need topping up, that would mean very little oil left behind on the cylinder walls, and therefore a greater risk of piston/bore wear in the long term.
Usually my oil consumption has been a long way below the quoted measurements (cars such as my old Uno 60 spring to mind), but there's always going to be the exception to the rule.
Now might be a good time to mention what I've learned about engine running-in. When new, the engine should be 'stretched' quite often to near its full performance, not all the time (risk of overheating) but run at a range of speeds/loads. None of this 'no more than 3000RPM' malarky, as that leads to the bores glazing, and then the piston rings cannot abrade enough to form a good seal. Likewise the first oil for the engine was historically always a basic oil; not semi-synthetic or synthetic, not 'friction-modified'. There was always an oil change after 1500km (and not before) to allow for this running-in. I note that this does not apply to the Stilo, which has its first service at 20,000km, implying that synthetic Selenia is used from the start.
So taking the above factors into account, and the ample torque of the Abarth model almost encouraging the use of low revs, I just wonder whether most Abarths did not enjoy a particularly great start in life, the piston rings not bedding in properly due to a combination of synthetic oil and light loading.
-Alex
