Guys,
I'm banging my head against a wall with this one, can't seem to find what the problem is. Car is a 1.9 8v JTD Sporting.
Symptoms:
Battery Light will come on and go off when ignition is turned on BUT engine NOT started. Car will idle for over an hour then start to get ASR, Power Steering messages/failures and then everything dies (no power), BUT there is no battery light illuminated and no message to say the alternator has failed/not charging.
Fitted a brand new battery and still same problem/symptoms.
Cars having it's MOT tomorrow so will ask them to check the alternator is giving out power, but would have thought i'd get the warning light/messages if it wasn't.
When I originally bought the car it had an extra wire going from the alternator to the engine fuse box which I assumed was an earth but thinking about it now it might have been a power supply. Would this mean that the alternator isn't being energized, so possible regulator problem. Or could it be the energizer wire is FUBAR ??
Davren
Symptoms:
Davren
