Hey guys,
Recently the car went into limp with a P1602 fault code and I would like to know what can trigger that on the ECU. I have checked battery voltage and alternator voltage and can find no failures. 12.4 V on battery and charging with some 14 V. The fault is constant and that should hopefully make it more easy to find the culprit.
I have a feeling that it might be caused by a broken wire/connection to the ECU - and would very much like to know which pins on the D4 or M10 that is used by the ECU (or BC ?) to kick of such a fault. I also wonder where the A/D converter thing is located. Thanks.
P1602 A/D converter
P1602 Battery voltage
P1602 Voltage circuit
P1602 Voltage regulator
P1602 A/D converter
