- Aug 14, 2011
- 258
- 80
If it's engine oil it'd have to be the crank seal, so have a look and see if the back of the flywheel is wet, if it's possible to see.
Got the clutch off. Can't really see up behind the flywheel but while there is a bit of oily stuff hanging around the general area, nothing overly excessive i don't think. I've had a good feel around the back of the flywheel and the the area around it as far as i can and it seems to be dry, there's nothing at all on those bits of the back of the flywheel that i can reach. Pics below.
I also drained out what was left of the oil in the gearbox, so all told got about a litre out of it (so it'd lost about a litre in the space of 300 miles). Pic attached from which you can see its quite black looking (per previous post) for oil that's only done 300 miles......
So given all of that, I'm coming to the conclusion that its been a gearbox leak rather than thru the crank seal, and s'pose I'm looking for some comment from you guys on here who are more experienced that this is a reasonable conclusion (rather than wishful thinking on my part......).
