rob.pollard
[ame]https://youtu.be/zmCS7-tUsXM[/ame]
Can anyone advise as to what this noise is a garage seems to think nothing wrong
Hi thanks for answering,Umm .. a wheel bearing usually 'sings' or gives a knocking / graunching noise - particularly when the steering wheel is turned sharply whilst the car is in motion. The noise that your car producing seems rather constant .. sort of like a driveshaft that has a worn joint, though that's not to dismiss a wheel bearing as the culprit.
Is the noise coming from any particular side of the car .. and did it just start suddenly?
I would have thought that a workshop would have been able to identify a worn bearing or driveshaft. You're absolutely certain that the noise is coming from the road wheels/driveshaft and not the clutch/gearbox area?
If the noise is coming from just one side of the car, try swapping the 2 front tyres around to see if the noise changes from one side to the other. If a tyre becomes 'bulged' it can create road noise.
Let us know how you get on.
HiWell easy question is, does it get faster with speed? Does it get faster with the engine RPM? Or is it always the same?
I've found several people on you tube with the same noise all saying bearingsSounds like a wheel bearing. But I could be wrong.....
