BaNzAsK
Hi All
I have been having a problem with the fuel and temp gauge for a while, the temp gauge didn't work when I brought the car one day the needle moved all the way around and hit the bezel and has stayed there since, the temp shows up using multiscan correctly.
The fuel gauge does not return back to 0 if I fill the tank any more than just over half way, once filled past half way the gauge does not return at all then when I turn the ignition on again it goes even further around and continues until it his the bezel..
How ever the fuel gauge I can get to go back if I quickly turn on the ignition and off again a few times quickly....
I'm unsure what the problem could be?
Thanks in advance
Thanks in advance
