This is a long shot, but have you thought about going through the fault diagnosis for the brake lights not working, it gives you the methods to check whether the brake switch is working correctly.
You don't think its possible the ECU was never programmed with cruise control, do you?
i fookin hope not!!! ive mutilated the cowl already and spent £50 on a stalk
nopes its a 1.8 02 dynamic.....any other ideas? all sorta pinning on this clutch switch....
I had the same problem as described here. Wired up everything as described here but my cruise control did not work. (1.9 JTD 8v built in 2002).
When I opened the black D4A connector which is beside the brown connector with the 4 cruise control pins, I found out that the pin A02 is not wired. This should be +12V when the brake pedal is not pressed. So I just pushed a wire into the connector and put it permanently on 12 V just to try out if it solves my problem. And it worked. In my case it does not mattter if there comes a permanent +12 V Signal on the brake signal. As soon as I press the brake pedal the cruise control goes off again.
I did exactly the same thing.i cut the cables going to A02, A03, A04, A05...and spliced them to the cruise control stalk cables....could the aforementioned problem contribute to my situation??
