im Axle Specialists
Old 25-03-2015   #1
South Africa
ECU Trouble PLZ help!!!!!
Hi all I have a problem I think its my ECU but not shore.
I tested my Heat sensor with a wire stupid i know but didn't have a tester and now the car doesn't want to rev and it gives me temperature sensor error the whole time. can it be the ECU? it starts and everything else works.
and if its my ecu can i get one from a other car? and must it be programmed or is it a plug and play?
dawie01 is offline Reply With Quote Quote
Old 25-03-2015   #2
Re: ECU Trouble PLZ help!!!!!
Quote Originally Posted by dawie01 View Post
Sounds like the error code needs clearing first and if all is well, the car should work ok from then on so long as you've not damaged the sensor.
Do you have Fiatecuscan software or a fault code reader?
2002 Stilo 1.6 16v
SGThirkell is offline Reply With Quote Quote
Old 26-03-2015   #3
South Africa
Quote Originally Posted by SGThirkell View Post
I have cleared it but the fault stays. As soon as I clear the fault pop's back up on the dash. Yes I habe the fiatecuscan and code reader
(T) Seicento ECU trouble Mark Ewing Cinquecento / Seicento 1 05-06-2014 13:47
Punto (Mk2/2b) Coil Pack / ECU Punto help plz mondo76 Newbie Central 5 06-01-2013 13:27
(T) cinquecento ecu trouble fatcento Cinquecento / Seicento 14 18-09-2010 13:20
(T) fiat punto xreg ecu help plz... trev1234 Punto (Mk2/2b) 0 09-02-2008 11:56
(G) ecu trouble punto18 Punto (Mk2/2b) 3 22-01-2007 00:51
