![]() | #1 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Water Leak into passenger footwell After months of struggle found the source of the water leak. The water coming from the joint underneath the wing.
![]() | #2 |
fiats = frustration ![]() | Re: Water Leak into passenger footwell do you have a skyroof check the drains also i would be more worried about that tyre, its way past illegal the air con unit also has a habit of becoming blocked, on the pas side there is a right angle hose that drains the air con unit. if that blocks it spills into the foot well. remove the pas side centre console cover and pull the hose of allow to drain and put a simpe drinking straw in there, this prevents a vacuum occuring and allows it to drain. change the pollen filter as if this is blocked the airflow will be low and freeze up the matrix causing a build up of water.
__________________ Current: 2006 Peugeot 407 sw 2.0d 2004 Fiat stilo 1.9 jtd dynamic multiwagon 2004 Fiat Stilo 1.6 Dymanic Multiwagon - sold april 2013 2003 Fiat Stilo 1.6 active aircon (with EBD) - Written off 22nd dec 2009 Last edited by roy lovelock; 06-12-2014 at 19:35. |
![]() | Stromboli | Ducato | 4 | 01-08-2011 01:04 |
![]() | Robtroll | Bravo / Brava | 11 | 25-01-2009 15:05 |
![]() | fastkab | Punto (Mk2/2b) | 4 | 01-04-2008 01:26 |
![]() | blackpool_uk | Punto (Mk2/2b) | 9 | 15-12-2004 22:07 |
Leak,back passenger footwell | Colin | FIAT Boo Archives | 3 | 03-11-2002 13:49 |
