![]() | #1 | ||
Posts: 20 Thanks: 0 Trader Rating: 0 ![]() | ![]() lost my handbook , so need sum help fin ding speedo sensor , and need to know which fuse is it for speedo ,, so I can check that first ,, glad for any help ,, many thanks
![]() | #2 |
Posts: 13,982 Thanks: 1490 Trader Rating: 5 ![]() | Re: stilo 1.2 , speedo sensor + which fuse for speedo There is no conventional speedometer sensor on the Stilo. The road speed signal to the speedometer comes from the ABS ECU which gets signals from the 4 wheel speed sensors mounted in the hubs. There's also no specific fuse just for the speedometer. The whole electronic instrument panel gets a permanent supply from fuse F37 (10Amp) and an ignition switched supply from fuse F53 (10 Amp), both located in the dashboard fuse box. You can download a handbook from the forum downloads section here: https://www.fiatforum.com/downloads.php?do=cat&id=5 .
__________________ Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514 Last edited by Davren; 08-04-2014 at 17:34. Reason: Added diagram. |
![]() | #3 | ||
Posts: 20 Thanks: 0 Trader Rating: 0 ![]() | Re: stilo 1.2 , speedo sensor + which fuse for speedo cheers , for that ,, its just my speedo as stopped working ,, not too sure why ???
![]() | #4 |
Posts: 13,982 Thanks: 1490 Trader Rating: 5 ![]() | Re: stilo 1.2 , speedo sensor + which fuse for speedo If the problem was with the wheel speed sensors, you would have an ABS warning light on and a message in the display saying ABS Fault. If you don't have that, it's likely to be a fault with the instrument panel, possibly the speedometer stepper motor not working. All four needles have their own stepper motor to move the needle. .
__________________ Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514 |
![]() | #5 | ||
Posts: 20 Thanks: 0 Trader Rating: 0 ![]() | Re: stilo 1.2 , speedo sensor + which fuse for speedo so I need another cluster of clocks ,, ( only thing I am getting is ( airbag light ) and ,, ARS light ( like a little spinning wheel , spinning gravel out ) ,
![]() | #6 |
Posts: 13,982 Thanks: 1490 Trader Rating: 5 ![]() | Re: stilo 1.2 , speedo sensor + which fuse for speedo I only said "it's likely to be a fault with the instrument panel". You would need to do further diagnosis to confirm it. MES software (www.multiecuscan.net ) a laptop, interface and the correct leads can be used to operate the speedometer needle independantly from the laptop. That would help with diagnosis. If it is the stepper motor, you can buy one seperately but they are tricky to remove and solder to the PCB, and it's easy to damage one, or more, of the other 3 motors while dismantling the cluster. http://www.ebay.co.uk/itm/251344604661?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649 If you buy a replacement cluster, you need to get one with a lower mileage than your current one because the mileage display can only be adjusted upwards. If you add your location to your profile, you may get offers of help from members that already have MES. .
![]() | #7 | ||
Posts: 20 Thanks: 0 Trader Rating: 0 ![]() | ![]() hiya many thanks ,, I replaced clocks ,, speedo works , but still have the beebing with airbag ,, ( also now have triangle sign with question mark ) on all time ,, ( these clocks , I got must have had a parking sensor on ) , cause that pops on , as fault , then goes away , ( triangle sign got me confused ) and that airbag , ,, cleaned all connectors under seat ,, still on , cant find any codes when I connect my machine ?????
![]() | bredsticz | Punto (Mk2/2b) | 17 | 26-12-2009 14:23 |
![]() | dubchie | Multipla | 2 | 17-02-2009 23:05 |
![]() | Mark_C | Bravo / Brava | 5 | 22-09-2008 10:21 |
![]() | oldmaninapunto | Punto (Mk2/2b) | 1 | 26-08-2008 18:15 |
![]() | FamilyGuy | Bravo / Brava | 3 | 29-09-2004 22:07 |
