Hi DaveG
This is the website for the Eibach springs.
www.motorsportworld.co.uk
Remember, don't buy direct from the web-site, email their customer services and tell them that Demontweeks said they'd do them for £120, then they'll email you back saying they'll beat them and do them for £109 inclusive of VAT and delivery. Eibach actually delivered them from their outlet in Leicester and invoiced Proline, the invoice was in the parcel and although it was supposed to be invisible, I made it out and they invoiced MSW for £89.98, so push them and they'll go lower!
Here is Eibach literature on their springs.
Question:
What shocks should I use with an Eibach spring system?
Answer:
Basically, Eibach spring systems are designed to work with original equipment shocks provided they are in good working condition. Aftermarket performance shocks - especially the Eibach Pro-Damper - will increase the overall performance of your suspension and are a recommended complement to the Eibach spring systems.
Question:
Will it be necessary to have my vehicle re-aligned after the installation of an Eibach spring system?
Answer:
Yes. After the installation of an Eibach spring system, the alignment of a vehicle should always be checked and in most cases adjusted. For further information on alignment, please see our general mounting instructions on the next page.
Question:
Will I have proper tire clearance with a “plus size” tire and wheel package after installing an Eibach spring system?
Answer:
All Eibach spring systems are designed and tested in combination with the original equipment wheels and tires. Installation of an Eibach spring system does not alter the original range of wheel travel and as a result, can never be the cause of clearance problems. It is best to work with a reputable wheel and tire dealer who is knowledgeable in the proper wheel size, width and offset that is correct for your vehicle in order to prevent clearance problems caused by improper tire and wheel packages.
Question:
Is it wrong to heat or cut a coil spring to lower a vehicle?
Answer:
Heating or cutting a coil spring in order to lower a vehicle is just plain foolish. These procedures are very dangerous and at the very least result in poor handling due to the changing of the original spring characteristic and pre-load requirements.
Stilo Part Number 10-30-001-01-22
The Pro-Kit is Eibach's premium suspension product and is considered to be one of the world's top performance suspension products. The performance and reliability has been proven in millions of Pro-Kit spring sets sold in all five continents and in over more than 40 countries around the world.
The Eibach Pro-Kit spring system is the first choice for enthusiasts when upgrading their vehicle's suspension, improving both the vehicle's performance and appearance. The Pro-Kit provides, quite simply... "The Look That Performs".
High ground clearance and huge fender-well gap inherent from the factory give your vehicle an unfinished look. Whether you plan to stay with your factory tires and wheels or adding performance wheels and tires, chances are, your car has "the lifted look". In reality a "Plus 1" or "Plus 2" wheel and tire package with a lower profile tire will exaggerate the large gap even more.
An Eibach Pro-Kit is designed to reduce the fender-well gap by safely lowering your vehicle, giving it a more attractive, sportier stance. The Pro-Kit is the perfect compliment to any vehicle, whether in stock form or fitted with a larger tire and wheel package. The Pro-Kit will set your vehicle off from others, giving it "The Look" you want.
All Eibach Pro-Kits are designed by experienced engineers specialized in chassis dynamics and are tested by seasoned qualified drivers. They are designed to properly and safely lower your vehicle's center of gravity through the use of proprietary progressive spring rates; reducing squat during acceleration, body roll in the turns, and nose dive under braking. Upon installation, your vehicle becomes exceptionally stable and secure under a much wider range of conditions and will provide years of enhanced driving pleasure, whether you are twisting your way through a mountain pass or cruising down the interstate or tempting the Autobahn.
Vehicles equipped with performance wheels and tires also need the additional performance provided by the Eibach Pro-Kit. Performance wheels and tires create a larger contact patch which increases the adhesion resulting in additional body roll. The Eibach Pro-Kit is designed to control this additional body roll becoming the heart of your performance suspension package.
Pro-Kits are available for nearly every model produced by over 40 European, American, Japanese, Australian and other main vehicle manufacturers out of Korea and Malaysia.
Getting your vehicle to look and perform "just right" is not an elusive recipe, in fact it's down right simple; wheels... tires... Eibach Springs.
Installing an Eibach Pro-Kit will take your passion for driving to a whole new level, one that can be further enhanced with the addition of other Eibach products such as our Anti-Roll-Kit or Pro-Control-Bar. For the demanding enthusiast or the daily commuter, an Eibach equipped vehicle provides the best balance between appearance, performance, safety, and ride quality.
Advantages of the Eibach Pro-Kit:
Excellent ride quality - comfortable in cruising
Sportive handling in cornering, resulting in improved performance
Lowered center of gravity, increased stability
Enhanced appearance of vehicle
Manufactured according to ISO 9001 quality system as well as TÜV approved
10 year product warranty
To find out if an Eibach Pro-Kit is available for your vehicle, go to the Application Guide on the menu to the left. To find the nearest dealer, use the Dealer Look-up.
Hope you get them on soon, it's a major improvement and dont listen to the scare stories.
Cheers!
