Thread Tools
Old 07-12-2011   #1
Failed MOT High Emissions.
Hi All,
New here so sorry if this is covered elsewhere. Had an MOT this morning on a Stilo Dynamic 1.6 and all emission readings were 9.9% so failed across the board.
I've read some post about injector cleaners etc wonder if these would make that much difference? The car has been sitting on my drive for a year now without being properly driven I wonder if a good run out will sort it out or if it something more serious?
Any help will appreciated.
Cheers Gaz
GazzaPenk is offline Reply With Quote Quote
Old 07-12-2011   #2
Re: Failed MOT High Emissions.
its worth a try, mine failed with high emissions, but was quite close to the limit.
i ran one of the cleaners through, took it for a drive at high revs and then took it into the MOT well warmed up, the MOT tester did the emission test 1st while still very hot, and it got through no problems.
dunno if it was the cleaner or just getting it MOT'd while hot that did it, but the cleaner costs less than 5, so cant hurt to try it.
02 Stilo 1.6 Dynamic 5 door, and another 02 Stilo 1.6 Dynamic 5 door
holloway1000 is offline Reply With Quote Quote
Old 07-12-2011   #3
yep, give the car a good run with fresh quality petrol and an ijector cleaner in the correct ratio mix. No point in running more cleaner thinking it will work better, it doesn't. and next time you test it make sure the engine is warmed up by doing at least 15miles before the test.
3 door 165JTD Dynamic Jet Blue with sky roof strut braces, decat and full s/s exhaust, remap, additional gauges coilovers, lower braces, 18s and vanillaroma magic tree
I'll be at the front making lots of smoke
rattystilo is offline Reply With Quote Quote
Old 07-12-2011   #4
Yellow Peril has donated!
In case no-one else mentions it: fresh oil, new filter, new air filter and plugs. And make sure the engine's nice and hot when you hand the car over.
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 14-12-2011   #5
Got it through the MOT just some Redex and a good run sorted it all.
Only problem now is a loose battery terminal, anyone know where I can source a new terminal?
Old 14-12-2011   #6
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
The battery post and the terminal are tapered. Loosen the nut then push the terminal fully down onto the post and retighten the nut while holding the terminal down.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 14-12-2011   #7
Sorry I didn't explain fully one of the bolts was sheared off through my over tightening
Old 14-12-2011   #8
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
You could use an ordinary 6mm bolt but I think the original bolts have a flat square head to prevent them turning when loosening/tightening the nuts. Not a problem on the negative terminal clamp because you can get a second spanner on it but the positive one would be hidden under the master fuse board when fitted.
If it's the positive one that's broken use the negative terminal bolt and fit an ordinary bolt to the negative terminal clamp.
Old 15-12-2011   #9
Stormwatch has donated!
Greece
I have an appointment for MOT test next week. What do you suggest I should put in the tank? Octane booster or injection cleaner?
Stilo 1.6, 2001 , 3D, Jet Blue
Stormwatch is offline Reply With Quote Quote
Old 15-12-2011   #10
Quote Originally Posted by Stormwatch View Post
Change the oil, then fill up with Shell Vpower (the high octane/Cetane increases cylinder temperature to help burn off the crap, heat the cat and lambda) and add some Redex, then give it a good run 70mph 4th gear, that'll give it a good clean
Also make sure you have a new or clean air filter in.
Because learning is fun
GrandeGuy is offline Reply With Quote Quote
Old 15-12-2011   #11
Quote Originally Posted by GazzaPenk View Post
You can buy replacement battery terminal bolts from Halfrauds.
Phil
Yellow Peril
Old 15-12-2011   #12
Greece
It's gonna be fully serviced on Saturday...
Old 16-12-2011   #13
Monday
Thread Tools
(T) MOT failed on emissions bigboot Punto (Mk2/2b) 5 29-07-2011 16:04
(T) MOT Failed: Emissions CinqyAbarth Cinquecento / Seicento 15 19-10-2009 20:15
(T) Just failed MOT on CO emissions - help KwikPhix328 Punto (Mk2/2b) 1 03-04-2009 20:15
(G) Mot Failed On Emissions????? riddick Panda (Classic) 4 02-06-2007 22:59
(T) High co emissions...failed mot sr3309 Punto (Mk2/2b) 2 24-05-2006 20:41
