Thread Tools
Old 17-08-2011   #1
refit starter motor/helpppppp
please help iam refitting a starter motor on a 2002 stilo 1600cc
but i have thre wires but dont no were no go back
2 large wires both red
and 1 small wire
1 red wire comes from battery
1 red wire from the back of engine maybe alternator
1 small black wire from loom just uderneath the maniford
pic would be very helpful
jjtyres is offline Reply With Quote Quote
Old 17-08-2011   #2
Re: refit starter motor/helpppppp
2 reds to the larger connection "B"
black to the smaller one "S" that you removed (if you cant remember which ones you removed then look for the shiney bits of thread on the solenoid studs)
all the connections go to the solenoid you will have a positive in "B"(battery wire) a ground out "M"(which could be a link wire to the motor casing itself) and a positive 'trigger' wire from your ignition "S".
the 'trigger' wire is a low power feed from your ignition switch, this energises the solenoid, which allows the power from the battery to be dumped into the starter motor itself, giving sufficient power to engage and spin the motor.
the wire 'going off to the alternator' is actually a 'return' feed from the alternator supplying 13.8v @ 80+amps... its connected to the same connection "B" as its an easy way back to the battery instead of running a separate cable back through the engine bay
teach yourself http://www.prestolite.com/pgs_training/training_4.php
Rich
'02 Stilo, 1.6, Dynamic, Black, 3 door, Full Leather, -30mm Apex Springs w/ Monroe Reflex Shocks.
'99 Coupe, 2.0 20v VIS, Portofino Blue, 2 door, Full Leather, Mani-Back Longlife Custom S/S Exhaust.
richydraper is offline Reply With Quote Quote
Thread Tools
(T) Starter motor... Dayjw Punto (Mk1) 5 12-09-2010 22:58
(G) starter motor help mje Ducato 2 07-06-2009 14:47
(T) Starter Motor GAZZA89 Punto (Mk2/2b) 0 09-12-2008 13:46
(G) Starter Motor????? please help jimnewson Bravo / Brava 13 06-01-2008 19:25
(T) how do i remove/refit starter motor loops84 Punto (Mk2/2b) 3 25-05-2007 17:18
