hi guys keep getting fault code p0401 anybody had this problem and whats cure i beleive its insufficient air supply to maf could it just be case of replacing air filter ??
hi thanks for replys i meant to of said egr in starting post whoops!!
why on my previous jtd stilos,when iv blanked off egr iv never had any fault codes come up, iv blanked this 1 off the same and p0401 keeps popin up??
Mine's a standard JTD 115 8v with two cats and no Lambda sensor so I've no idea how the ECU knew to throw up the P0401 code when the blanking plate was fitted.
I doubt it had anything to do with blanking off the EGR, probabely a loose or corroded connection somewhere that fixed itself when you were messing with the EGR. As you say, there's no way for the ECU to know the EGR is blanked off so it couldn't throw up a fault code.
thanks davren mines the multijet 120 bhp 8v il try swirl gasket and see how it goes previous stilos i had were jtd 115bhp 8v but egr valve and pipework is exactly the same and i do get the engine managment light come on
any 1 know part number for egr valve 120 multi jet as seen 1 on ebay for vauxhall ,part numb is 55215032 is that the same as my multijet ??
