Old 17-12-2010   #1
1.9 Mjet =)
DarrenClark's Avatar
Trader Rating: 1
DarrenClark has donated!
Flywheel
Has anyone converted the dual mass fly wheel for a single solid flywheel on a 1.9 jtd stilo? Would it be possible?
DarrenClark is offline Reply With Quote Quote
Old 17-12-2010   #2
Re: Flywheel
good question and one i would be keen to see the answer too as my flywheel is going to be a problem soon.
3 door 165JTD Dynamic Jet Blue with sky roof strut braces, decat and full s/s exhaust, remap, additional gauges coilovers, lower braces, 18s and vanillaroma magic tree
I'll be at the front making lots of smoke
rattystilo is offline Reply With Quote Quote
Old 18-12-2010   #3
sussexa has donated!
Re: Flywheel
yes but its a 16v jtd, but im sure there is one for 8v.look in here.
http://www.alfaowner.com/Forum/alfa-...uestion-3.html
have a read from start,wont take long.
heres where i got mine from
http://www.gsracing.it/gsrcommerce/S...DProdotto=8112
search for ahm alfa,
http://www.alfacare.co.uk/Servicing/Clutchrep.htm
they were going to make one but hadnt yet when i ordered mine.
briefly 1 its expensive, 2 its noisier than dmf(when not in gear), 3 it loses momentum easier,4 expect more gearbox wear from increased vibrations and instant loading.
but 5 expect reliability at higher hp, 6 more rev happy.
hope this helps.
sussexa is offline Reply With Quote Quote
Old 18-12-2010   #4
Re: Flywheel
Hey Sussexa (no other name to address you),
If I've understood you right.. you reckon your Stilo's flywheel is going to need replacing?
If so, then I a have two questions:
What about the Clutch kit? Have you already replaced it?
How many miles have you done?
I need to know as my stilo's clutch is definitely in need of replacement (done 60,000 miles) so I don't want to leave the flywheel unattended if it will need replacing after 10,000 more miles or so; might as well get it done one time.
Would appreciate if you could share you views on this.
Fiatbydesign is offline Reply With Quote Quote
Old 18-12-2010   #5
Re: Flywheel
no, its already been replaced with the smf and clutch kit shown in the links above,(although c.g.motorsport relined the clutch disc as it was damaged in transit)
so far no issues(other than the points i listed), 10,000 miles on
i believe the dmf can be checked for excess wear/movement when clutch is being done.
if your not looking for high hp/nm i would stick to a dmf again.
it was all fitted at 25,000 miles, clutch slipped from 10,000 miles odd as soon as it was upped to 180hp 370nm when in 5th or 6th gear.
and hopefully will end up 200hp 440nm + so i chose smf.
oh and i definately recommend c.g.motorsport .
http://www.clutch-specialists.co.uk/...mber&x=26&y=13
actually will this fit the 8v ? ill post here as its smf
http://www.italianspares.co.uk/produ...cat=253&page=2
these are the guys who actually fitted my kit nice fellas and probably advise you over the phone if you want their opinions.
Old 19-12-2010   #6
1.9 Mjet =)
Trader Rating: 1
Re: Flywheel
My car on 151 000 miles for clarification, so in fairness i think it done well lasting this long
Old 03-01-2011   #7
Re: Flywheel
someone on alfa forum seems to have fitted a fiat coupe 20v turbo smf on his 8v jtd,if he posts any more info ill put it in here.
also have heard of dmf getting welded fixed and balanced.
also in my posts above some of the downsides are due to it being a lightweight smf(smf 8.2kg approx vs dmf 11kg approx).
(T) 1.6 flywheel Oletimer Multipla 0 06-12-2010 20:53
(G) Flywheel? seany_222 Punto (Mk2/2b) 2 05-09-2009 16:35
(T) Flywheel mustard Cinquecento / Seicento 9 06-06-2009 12:31
(T) DM Flywheel beany_bot Grande Punto 4 17-04-2009 18:48
(T) flywheel ebs Other Fiats 0 17-05-2007 22:22
