Technical Torque Wrench Settings pelase
South East
Does anyone have access to the techincal info that could give me the torque settings for the following bolts:
1) Horizontal bolt thru the front bush on the front suspension lower wishbone
2) Rearmost vertical bolt that secures the front subframe to the floorpan
3) The four vertical bolts that secure the rear beam axle to the floorpan (just ahead of the bushes).
Settings needed for fitting chassis braces.
Cheers chaps.
Front Wishbone Bolt - 100Nm, Rear Wishbone Bolt - 105Nm
Crossmember to Bodyshell - 150Nm
Mounting to Bodyshell - 50Nm
Have fun! (y)
