kevinbarr
Having had the 'loose connection' fault stop my Abarth in a couple of very dangerous positions (on a roundabout & overtaking a bus during rush hour), I thought I would let you know the ups and downs and cure.
Car would say that there was 'auto gearbox failure' in RED. Car would then stop in gear, even in 4th. Car would not start and would read 'loose connection, and 'engine diagnostics failure' in YELLOW. Half hour later car would start but yellow 'engine' light lit. Start and stop engine a few times and 'engine' light would go out. Fine for a week then died (overtaking bus!). Took car to Fiat (after getting light to go out). Found to be the RPM sensor and not a 'loose connection' after all. The part that tells the car there is a fault was at fault!!! £39 + labour.
Hope this is of help to anyone that gets the 'loose connection' error.
