Since this thread, I've had a new ECU fitted, this has solved the revving problem Hooray!!... But now the engine cuts out when the revs drop to approx 10k. Which is basically every time I take my foot of the accelerator. The garage have said they have done everything they can , there are no fault codes showing so I'm $1,500 out of pocket with a car I can't use. I've tried cleaning the Throttle Body with Carb Cleaner, having read treads on this site however, this hasn't helped, but I've only tried to clean it while still on the car, should take the Throttle Body off the car to clean it, if so is it just a case of removing the four bolt and the electrical connection.
