Re: Stilo 1.9 JTD 3D
Appreciated the info in this tread, was very helpful to me, Cheers guys
This may sound silly but, has any modified their battery tray to fit a bigger battery, if so could you let us in on a few pics or some info on how to modify it please.
what would everyone recommend as the best battery to put in a stilo?
I though I would share these pics so that if anyone like me previously searches or has any questions in relation to replacing their Stilo battery these pics may help .
Battery tray dimensions in JTD Stilo:
L = 30cm
W = 19cm
H = 20cm
The VARTA is an E44 model, 77ah and 780A (cold test current). The long clip in one of the pics is what you can remove from inside the tray to fit a bigger battery so Mr Davren pointed out to me a while ago .
Only downside i had was that due to the new battery being around 3 to 4 cm longer i had a niggly issue trying to fit the battery cover back in, after a few huffs and puffs it was all sorted, kind off .
Oh and the battery difference, well worth its money :slayer:
They do (E44 is an 096) but Ballackcanavaro99 didn't have an 096 fitted in the 1st place so it looked like a more difficult job.I thought the VARTA batteries fit straight in Perfectly?
That's an 096 which should fit in perfectly. The only modification you may have to make is to discard the plastic locating strip from the bottom of the tray.
