kettyaprilia
- Dec 30, 2009
- 1
- 1
Hi guys.. I have an 02 Stilo 1.6 dynamic. Great car in the main but I have a problem that I would much appreciate any advice or a fix on.
Last night after the car had been parked for about three hours i went to it only to greeted by a noise that sounded like the radiator fan was on.. The battery was completely dead by then. I disconnected the battery leads and left it overnight. After getting a homestart recovery, I was advised to purchase a new battery which I did straight away. The garage fitted the battery and advised that my coolant was low so I had a couple of litres added.
With the new battery fitted, off I drove.. problom solved.. or so I thought. This eve I heard the noise of the fan operating from inside my house. I rushed out and started the car up, concerned for the new battery. Each time I then turned off the ignition, the fan started running again. I have located the radiator fan fuse and removed it for now. I did describe the intial events to the garage fitting the battery and obviously they just were confused that i was suggesting the radiator fan switched itself on and couldn't really offer advice.!!
All that I can recall that may be siginificant, is that earlier in the evening, I had inadvertantly driven through a large puddle on the kerside.
So.. how do i fix this... ?? Has anyone had the same issue with a stilo?
