This can't be right. Mine is lowered 30 mm on sport shocks and is lower at the front than this red one.
I did notice that after the post which is why i attached the small pic after because the car was on a slop lifting the front abit on that side.
From what I've heard and indeed seen, the lighter engined 1.2 will always drop by less on the Sportlines or other 50mm springs than others due to said lightness of the engine. Noticed that with mine as well. Doesn't look too odd though and getting slightly larger alloys will help it look better too (OEM probably, not aftermarket).
With regards to speedbumps, I don't "attack" them at the same speed I used to, but have never even come close to scraping the front or back. And never had issues elsewhere like multi story car parks.
this is my ride height.. its about 100mm i think
Surely that low you can't use full lock? Which can't be good! First time you forget you ruin you wheel arch, liner, tyre wheel potentially! Your tyres are actually buried in the wheel arch, so if you drive around a tight 90 degree bend, understeer for whatever reason and apply some more lock and then hit a bump your going to careering into a ditch with your wing flying past you!
And you have no problems with bump steer? I've seen some horrendously lowered Corsa's bump steering their way along lightly potholed roads! (granted they are Corsas haha).
there is hardly a road left in the UK that isn't forked due to the Government stealing our roadtax to fund war rather than fix roads.
you didn't tell him your drop size.. :yum:
I can have anything from 50-120kg in the boot and have so far used 7 8kg sheets of deadening with more to go. Cheers guys.
my boot is full of ice..
and my rear is lowered the most it can possibly be lowered with any suspension kit, and it doesnt rub...im on 17 x 8.5j
however i tryed to fit 30mm spacers, and it nearly wripped my tyre up in 50metres, so they came straight off..
there in the garage if anyone wants to buy them, hubcentric aswell
Rim width, diameter and size in general - it all comes down to offset.
High/deep offset might require spacers, like putting a Ritmo Abarth 130 TC 14" alloy to a 1.1 ie Uno require 25 mm spacers to achieve correct tracking width.
Also remember that the rear body of the Stilo is offset the axle itself... by some strange reason. Measuring the length from the outer wing to tire on the left side will not match the lengt on the right side.
