So 60mm on Eibachs would be a safe idea then
I still cant help but want airbags though lol
Thanks for that.Wouls everybody agree that mine looks like it has dropped about 10mm in comparison. Also i thought that the aftermarket springs were stiffer so the weight will make less difference and the weight of the engine did make a difference.
Many of the cheaper lowering kits only come in 2 variants which accounts for many discrepancies in ride height.In terms of the engine weight, it definitely comes into it as when you order the springs I believe it asks if you have a 1.2/1.4/1.6/1.8 or a JTD/2.4, the latter selection being the heavier engines (though I don't know what the KG difference actually is offhand). If Eibach themselves have different kits for different engines, then I'd deduce it's because of the weight as the dampers are the same no matter what model you get.
Threads like these still make me laugh - living with a lowered car, especially one you use daily, is a nightmare! I've done it once and would never do it again.
Final thing and I'll crawl back under my rock... the stilo has huge arches, anything less than an 18" just doesn't look right, 16" just exaggerate the arch especially if lowered. Muppet24's pic is a good example
18" on a 40mm lowered car, looks sooooooo much better
http://www.europerformance.co.uk/pages/products/product_info.mhtml?product=4018982So ive been reading through this thread guys and i to want to lower my stilo, Although i dont know which kit to get. I want to lower it 40mm i think. Could someone link me to the right kit by any chance? Eibach springs fo sho!
I have a 1.4 stiilo blue
coyle, whats the point in lowering the front more than the back? Wont it look odd? I want it even all around.
ordered! My cars going down down down XD![]()
i think the back is a bit heavier than the froont, so it requires less drop than the front because you already have the weight weighing the back end down...if you know what i mean.
Refer back to post 46..
You'll be soo~oory.......
Front HAS to be heavier... the engine & gearbag are up there!
I can only assume the 1.2/1.4 is quite different to the rest of the range thenif you mean the living with a lowered car is a nightmare.. i disagree, especially at only 30-40mm
