Thread Tools
Old 19-04-2009   #1
sussexa has donated!
jtd 16v swirl flaps
hi can this be stuck as a sticky info on swirl flaps and actuators.ta
http://www.ms-motor-service.com/xima...093_en_web.pdf
sussexa is offline Reply With Quote Quote
Old 20-04-2009   #2
Re: jtd 16v swirl flaps
Swirl flaps are very dangerous things. Just ask a BMW Diesel owner. They have a habit of breaking off, going into the engine and destroying it. Bent valves, scored bores, cracked pistons. A small piece of metal can do a lot of damage inside a diesel engine.
The best advice (and BMW forum opinion) is to remove them. I have on my 320D and it makes 0 difference to the running of the engine / economy since I removed them. It also means the engine will go on for ever, instead of destroying itself in a cloud of smoke at some very inconvenient moment and costing 4K+ to put back together.
Pierburg also make the BMW inlet manifolds / swirl flaps as well as the these fiat/ vauxhall ones, and on some others too. Most makes of 16V diesels with swirl flaps have had issues of failure. I know Vauxhall certainly has.
Also, soon even petrol engines will be fitted with swirl flaps, to meet new euro requirements although I suspect they will not take such a beating as there is no turbo or EGR gunge in a petrol engine manifold.
john55 is offline Reply With Quote Quote
Old 20-04-2009   #3
JFL
you penis!!
JFL's Avatar
JFL has donated!
Kazakhstan
someone i work withs vectra has the swirl flaps on the 1.9cdti 150 and they have stuck/broke.. he fixed them with a washe i believe and therew working okay
FAMILY WAGON..... WITHOUT THE FAMILY
BRAVO 150 MULTIJET DYNAMIC
FANCY A BUM?
JFL is offline Reply With Quote Quote
Old 21-04-2009   #4
whats the purpose of a swirl flap?
2008 Fiat Bravo T-Jet 150 Sport
2014 Fiat 500 S
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline Reply With Quote Quote
Old 21-04-2009   #5
Yellow Peril has donated!
Quote Originally Posted by Big Black Stilo View Post
Something to do with improving fuel mixing by introducing greater turbulence in the air being drawn into the combustion chamber I think. But John55 is right - avoid them like the plague! Do a search on Google - there are a lot of very unahppy people whose engines have been seriously knackered by disintegrating swirl flaps!
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 21-04-2009   #6
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Although not electronically controlled, there was a similar system in the old 1985 Croma CHT (Controlled High Turbulence)
Dave.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 21-04-2009   #7
Basically it turns your 16V engine into a 12V engine at low RPM. Blocks 4 inlet ports which makes the air mix better with the fuel as it is injected. Air enters the chamber at higher speed (through only one valve) and swirls inside the cylinder, aiding efficient combustion at low load / low speed conditions. When more power is required, the swirl flaps open and it becomes a 16 valve engine.
The valves are small, delicate and under a lot of stress in a diesel. See my other post about failures.
Old 21-04-2009   #8
do the t-jet petrol engines have them or just derv?
2014 Fiat 500 S
Old 21-04-2009   #9
I don't think any production petrol engine needs them yet to meet euro emissions standards. I think they are still in development by manufacturers. They will not actually fit them to cars unless forced to by new Euro standards, because it all adds cost. I could be wrong though.
Old 21-04-2009   #10
if i have they are coming off
2014 Fiat 500 S
Old 21-04-2009   #11
arc
this is where i stand
arc has donated!
the starjet engine has these flaps, i dont know if the T jet is a starjet or not, but i assume it is. gimme a min, i'll see if i can dig up some pictures
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 21-04-2009   #12
starjet is non turbo. Tjet is turbo (but you know that already arc!)
i hope they havent.
anyways, if they had would it not improve slow speed performance by removing them?
2014 Fiat 500 S
Old 21-04-2009   #13
arc
arc has donated!
yeah, just wondering if thats focusing on the trim levels or base spec. There is no reason why the starjet gear (cam variator and variable inlet stuff) can't be present on the Tjet engine - and the 'tjet' just means it has a turbo as well.
found these. Its from the GP, but it shows the swirl flaps.
Quote Originally Posted by dave View Post
here some pics of bits you wouldn't expect to see for a few years yet.
photos of star jets bits
plastic starjet throttle body even the butterfly is plastic
soon they be making plastic engines
Old 21-04-2009   #14
oh boy
2014 Fiat 500 S
Old 21-04-2009   #15
arc
arc has donated!
i don't know what the systems are like on the BMW, but glancing at the GM solution shown in the PDF - they're a bit clunky and over the top for what they need, and FIATs solution is better and much less prone to breaking. I would be suprised to hear of a failure where debris enters the cylinders
Thread Tools
Swirl Marks amcand Car Care 20 11-01-2009 17:08
Swirl Marks T-Jet 120 Car Care 47 31-01-2008 12:26
Fine Swirl Removal tips? Ben B Car Care 9 29-05-2007 02:43
(G) Swirl pot the mk1 kid Uno 6 04-01-2007 22:50
(T) Oil catch tanks and fuel Swirl pots? jamie86 Cinquecento / Seicento 14 21-02-2006 00:11
