gthomas
Hi, can you help at all,
the car is a 1.9 JTD 2002 Dynamic 17" Claws 82,000 that I have had since 2003 and I have some noises at the front of the car.
It sounds like a rumbling that increases with road speed and is loudest on engine braking and braking.
The noise is still there when the clutch is depressed and the gearbox in neutral but slightly quieter.
There is a fine vibration at times through the steering wheel and vibration now through the throttle peddle. Sometimes the steering wheel will pull to left slightly under braking.
The engine itself has a noise when parked that also sounds like a rumble. This decreases when the belt is wet. ( splash guards off at the moment for easier access )
What's been changed:
Cambelt and tensioners at 72,000, original water pump. (wrong move on water pump)
Aux belt and main tensioner bearing - recent.
both wishbones - recent
both front wheel bearings - now
one trackrod end - now
Front discs and pads at 72,000. (Hair line crack runs the length of one pad towards outer perimeter of disc, near side)
Both rear dampers - now
Test drive by dealer techs undetermined maybe wheel bearing. - since changed and one bearing faulty. noise persits
Clutch - original, some deterioration in pulling away, acceleration good, no blue smoke.
Driveshafts - original, some backlash, no clicking on either steering full locks.
No dashboard errors, no error codes. (yet)
and in a lighter vein, there is more heat from the heater on right hand turns only. (lol)
There is not a lot left to change but would appreciate any possible avenues to identify where the problem might lay.
Thanks Gerald
Locn: Maesteg - Mid Glam.
Thanks Gerald
