im Axle Specialists
Old 09-03-2008   #1
Brake Light Problems
Ok first of all, bear with me, im a little tipsy at the moment.
Earlier this evening (when sober) i noticed when at some traffic lights, if i revved the car, the brake lights come on. Subsequently pressing the gas pedal quickly, turns on the brake lights.
Hmmm.... bad earth?
Me-thinks not.
I had a replacement brake light switch done in the early days of owning my car as the lights stuck on, and since then it has been sensative... ie comming on with a feather touch.
No i notice its about to start sticking perminantly again as pressing the brakes puts the lights on but not every time they go off.
Tried to read the guide but my heads not working properly at the moment, even when sober!
Does this sound like something that can be adjusted out of the switch, or is the switch buggered and needs replacing?
2008 Fiat Bravo T-Jet 150 Sport
2014 Fiat 500 S
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline Reply With Quote Quote
Old 09-03-2008   #2
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Re: Brake Light Problems
Switch just needs adjusting.
Strong coffee first then, with some long nosed pliers at the ready, push the brake pedal down, then grip the brake switch plunger and pull it out (down) further, (you may feel the ratchet mechanism), then carefully allow the pedal up again without pulling it up
Name:  brake light switch.JPG
Test by raising your rear hatch so you can see the hi level lights and see where and when the lights come on now.
Thanks Big Black Stilo thanked for this post
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 09-03-2008   #3
cheers decks, as well as that coffee (well sausage buttie) i need to go retrieve the car from the local pub car park- 2 miles away, then i can have a go at it.
Hopefully it is just the adjustment.
2014 Fiat 500 S
Old 09-03-2008   #4
well just got in from doing this and i think its solved
was just an adjustment, (although i broke the retaining plastic clip things to hold the trim on thats over the pedals). tried it before fiddling with it and revved and brakes come on, press brake, release slowley, they stuck on.
Pulled the pin out using fingers only and it seems to have fettled it.
Cheers decks
2014 Fiat 500 S
Old 09-03-2008   #5
Deckchair5's Avatar
Excellent.Throw away the over foot panel,it's just a nuisance, you'll probably hear the indicators better now too as that's where the noise comes from. They often interfere with the movement of the clutch pedal too. Mine was discarded years ago
99 Bravo 1.2SX
Old 09-03-2008   #6
Driver Extraordinaire
minimad99 has donated!
Quote Originally Posted by Deckchair5 View Post
Mine to, much better without
minimad99 is offline Reply With Quote Quote
Old 09-03-2008   #7
adamcot has donated!
That panel fell on my feet 10mins after picking the car up, wasnt a good start I managed to bolt it back up there, just in case it was important, wasnt quite sure. I shall take it off now
Porsche Boxster S, Abarth 500
adamcot is offline Reply With Quote Quote
Old 09-03-2008   #8
mines now in the boot!
2014 Fiat 500 S
Old 14-03-2008   #9
agus an Stilo bn
daithi has donated!
Ireland
does that cover just clip off? i've to re-adjust my brake switch as well. i had just picked up the car (private sale) and my friend driving behind me rang me to ask why i was holding my foot on the brake and not to be so cautious. i was very confused as i wasnt pressing the brake peddle at all. but now thanks to the fiat forum, hopefully i will avoid a hefty dealership bill.
Fiat Stilo 1.2 Active
Kildare, Ireland
daithi is offline Reply With Quote Quote
Old 14-03-2008   #10
the cover comes of easily.
each clip/pin thing needs to have the centre pushed through so it will unclip.
I forgot this and went at it like a bull in china shop and snapped every collar so i need new ones to put it back.
However i decided to skip it as my size 12s fit better now
2014 Fiat 500 S
(G) High Level brake light nattyfatty09 Stilo 4 04-03-2008 15:02
(T) heeeelpppp!!! starting problems, ecu light stays on, S O S!!! joe9k Punto (Mk2/2b) 5 04-11-2006 22:46
Brake Light Switch: ESP/Lights/Selespeed Problems? Deckchair5 Stilo 0 15-09-2006 16:40
(T) Cinq 1 rear tail light - brake light on with lights? h10ndr Cinquecento / Seicento 4 11-04-2005 13:42
