FIAT Auto Specialist Team
Thread Tools
Old 23-04-2007   #1
Angry Leaking climate gas
Warm weather is upon once again and so its time for my climate to stop working. Had the Multiwagon from a mere 6 months old on 52 plate and every summer since had to have it re-gassed although when checking they cant find a leak, SO WHERE THE FOOK DOES IT GO......!
HONESTJOE is offline Reply With Quote Quote
Old 23-04-2007   #2
Re: Leaking climate gas
Have you used your aircon during the winter months? If not, then the gas would have escaped from the contraction of the o-rings, which seal the pipes.
The o-rings are a rubber compound and contract in cold weather.
sduffield is offline Reply With Quote Quote
Old 23-04-2007   #3
fiats = frustration
roy lovelock has donated!
spot on, the gas actually lubricates the o rings which keep them sealed (and stops them contracting), i always run my aircon for about 10-20 mins a week all though the winter months.
roy
roy lovelock is offline Reply With Quote Quote
Old 23-04-2007   #4
Brain freeze
LoBsTeR's Avatar
LoBsTeR has donated!
The manual recommends to run your aircon for 10 minutes per month to prevent leakage.
Stilo JTD 115 3dr Dynamic 2002 with Skyroof, 16" Alloys, in Pitti Blue. No mods........yet
LoBsTeR is offline Reply With Quote Quote
Old 24-04-2007   #5
Cheers but yes i run it all year round, unfortunatley this doesnt help.
Old 24-04-2007   #6
fiats = frustration
is this an air con specialist or just a re fill garage?. You will probally better off getting a expert to look at it as the ones in tire garages wouldnt spot a leak even if there was a massive arrow saying LEAK HERE on the car. You will probally re coup the cost after a couple of years with the amount of re fills you have had.
I know the stilo is prone to having cracked plastic pipes on the system, these are pretty easy to find on the car, it maybe worth checking these out, and maybe getting the soapy water out once the things been presurised.
roy
Old 24-04-2007   #7
NobodyBlamesTheHappyGuy!
Morty Mort's Avatar
Trader Rating: 2
Morty Mort has donated!
Norway
Fiat refilled mine with colorized gas, which is traceable with some special lamp. But it never leaked again. The car had been stored for a year before I bought it and all gas had vaporized or something.
Morten.
jet blue. eibach pro system. omp bar. gsr in. supersprint out. hella eyes. phoenix gold watts.
member of the 5-door massive attack.
Morty Mort is offline Reply With Quote Quote
Old 24-04-2007   #8
PNL
Banned
PNL's Avatar
PNL has donated!
Cool Re: Leaking climate gas
http://www.spangerum.com:7080/navi?C...D=1&GUI_LANG=3
This is a view of the system and the pipe on the bottom left of the rad is a favorite culprit and breaks ..mine is broken there..
PNL is offline Reply With Quote Quote
Old 24-04-2007   #9
My MW on a 52 plate has also lost it's aircon gas.... I run it all year round also. However this is the first time I've needed a re-gas in 4 years so can't complain
At last something that has lasted for more than the manufactirers warranty
[COLOR="Red"]2003 52 Plate Stilo Multiwagon 1.9 JTD 115 Dynamic, with skyroof Connect+ SatNav, electric seats, heated seats, split opening tailgate, Xenon Gas Headlights, Sliding Rear Seats, Leather Steering Wheel with remote controls for Audio system, Cruise Control, Stability and Traction Control, Factory Alarm. Only thing missing is Leather trim and parking sensors!!!![/COLOR] [COLOR="Blue"][I]& 2002 52 Plate Stilo 1.6 Dynamic with parking sensors, auto lights, auto wipers[/I][/COLOR]
ursabear is offline Reply With Quote Quote
Old 25-04-2007   #10
Cheers all for the advice, and your JTD is the same spec as my MW 1.6 petrol so good luck !
Old 25-04-2007   #11
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
There aren't many air con systems that are totally gas tight, a bit like tyres, a lot of them have very slow leaks and when you're talking years then that's a very slow leak indeed.
Even if it is gas tight (and some systems I know can last a lifetime without leaks or need topping up) the thing is, it could really do with a drain down and refill as otherwise it's the same oil going around the system year after year and that's counter productive and costly in the long run as there's a compressor in there working hard with little pistons going up and down like the clappers
So, having an annual system check, drain down and refill is well worthwhile and can make a big difference to efficiency otherwise the compressor is working twice as hard all the time
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 26-04-2007   #12
Got mine booked in for a service and re-gas on Friday, £67 inclusive. As I'm taking it to the garage and not being done at home I'll get a discount off that price too.
Found the company online www.coolcaraircon.co.uk based in Solihull and will do home calls within a 30 min radius of Solihull....I'm just outside that radius so taking it to them hence discount
I'll let you know what I think when it's done.
Old 27-04-2007   #13
Had the air con looked at, gas was fine, turned out it was a blown fuse... then came the next problem..... the fuses in the battery compartment are corroded into place ...I managed to break the air con fuse getting it out and then spent the best part of 2 hours trying to get the broken part out .... did manage it in the end, replaced the fuse and hey presto the air con now works.
coolcaraircon.co.uk only charged 25 for the top up of gas, it had lost a bit but not enough to stop the aircon working.
Old 28-04-2007   #14
Driver Extraordinaire
minimad99 has donated!
ursabear,
which fuse number was it? i may check mine later as i'd assumed it was empty.
cheers
minimad99 is offline Reply With Quote Quote
Old 30-04-2007   #15
ursabear,
are you there?
Thread Tools
(T) Engine not taking gas Ryanlittel Uno 8 30-01-2006 22:40
(T) Fiat Punto '04 and 4th generation gas equipment cYbeR_cat Punto (Mk2/2b) 3 11-01-2006 09:58
(T) Air Conditioning (climate system) controls ben743 Tipo (Classic) 8 04-03-2005 14:31
(G) gas conversion cinq Emm Cinquecento / Seicento 8 22-12-2004 17:47
