Hi guys,
Just got a question about MPG for my 1.6 Sport Active 3 door 2004 Stilo…
I recently topped up the oil (it was a bit low), sorted the tyre pressures and filled my car up with fuel from Shell (normal unleaded) right up to the brim.
Ever since I’ve done this (it might be all a coincidence!) but my MPG seems to have dropped. I normally average about 32mpg (is that any good, seems a bit low to me?) but I have been recently watching my instant MPG and getting some very strange readings…
When I used to set off in 1st or 2nd, it would normally read about 10-15mpg, now it reads around 3-6mpg!
If I block change the first 3 gears, its again around 3-6mpg until I totally get off the throttle and then put it back on, then it goes up to around 25-30mpg, but with the same amount of throttle/rpm/speed! It never did this before, it used to be around 25-30mpg through the first 3 gears. It seems as if when I totally get off the throttle it resets something and then starts running at the correct mpg when I get back on it.
Any ideas? Could be the type of fuel I’m using? I’m not sure if my average mpg has dropped as I’m driving differently to stop this (i.e. dropping down to 3-6mpg) from happening at the mo! As a test what sort of mpg should the 3 door 1.6 do at 70mph on a flat motorway in 5th?
Matt
:worship:
Matt
:worship:
