Note if you want to just change your battery - skip to the next page.
OK, so I like to fiddle and I like little details. As you'll see in my pictures, my original 3 button flip remote is looking a bit grubby and tired. It's also blue. My Abarth isnt blue. My Abarth is black. This simply will not do!
So for about £4 off good old eBay you can have yourself a new key fob case. You can get the normal blue or, because I wanted black to match the car, I ordered a black one. It makes it easier to see what's going on in the pics too.
So what you're going to need:
Your current / existing key
A new key case
A small phillips screw driver
A small flat point screw driver
Optional:
New key fob battery (may as well whilst you're at it?)
Guitar pick or similar soft plastic tool / credit card
Some form of glue or double sided tape
Tweezers
Disclaimer - there is a risk your key drops it's coding when the battery is removed. Never happened to me but there are threads reporting this in Stilo section. To help you out in this eventuality, before you start, unlock the car via the remote and open and close the drivers door - to stop re locking. You can then always use the key as opposed to remote if needed.
OK - lets go....
A new key case
Optional:
Tweezers
OK - lets go....
