Comment
Guide Tools
<!-- google_ad_section_start -->Retrofit Steering wheel with buttons<!-- google_ad_section_end -->
Est time: ~2h
Published by andreist31
12-02-2012
Difficulty Level: 3
User Rated:Unrated
What is involved and tools needed before starting
In order to retrofit a steering wheel with buttons on a stilo without buttons you need to follow this guide. If you switch a steering wheel with buttons with another with buttons (maybe put an 11 button instead of 5), use page 2 and 3 to see how to take the steering wheel out, then just follow the steps in reverse order to fit it back.
Some photos in this guide are not taken by me, but have found them on a german site.
Right now getting back to retrofitting, here are is what you will need:
  • A steering wheel with buttons
    A clock spring from a car that had buttons on the steering wheel (they have different connections than a normal clock spring i.e. the normal clock spring has 2 airbag connections and a horn connector (white in colour) whereas we need one with 2 airbag connections and a multiplexer connector (will have more that 2 wires and black in colour) )
    A 24mm socket with extension and a ratchet
    A 5 allen bit or screwdriver
    A PZ1/PH1 (+) screwdriver
    A soldering iron with a sharp tip (soldering skills needed as well)
    Solder paste
    3 rolls of wire (3-5 amp wire found at any ICE shop, i.e. Halfords)
    3 wire clamps Click image for larger version
Thanks BLUEDEVILUK, aaronmarton, RainMan1, ben, blink182 and 1 others thanked for this post
Contents
<< <    Next Page: Preparing everything (Page 1 of 7)    >  >>
Old 14-02-2012   #1
Re: Retrofit Steering wheel with buttons
thanks alot. cracking on with this soon at the same time as installing the connect nav+ seen as ill be in there.
clock34 is offline Reply With Quote Quote
Old 16-02-2012   #2
Stilo Passionate
andreist31's Avatar
andreist31 has donated!
Memory Champion, ZNEMDROPS Champion
Quote Originally Posted by clock34 View Post
Good luck! Will post an updated guide with photos for the CN+ as soon as i get out of hospital, might be tomorrow might be in a few days doctors in ICU don't know yet, but will do one
Andy
andreist31 is offline Reply With Quote Quote
Old 10-05-2012   #3
thanx for this fitted myn today and works spot on thank you
chrisboulton is offline Reply With Quote Quote
Old 20-06-2012   #4
jonathanbees has donated!
is the clock spring the same for 6 or 12 button wheel i have a 115 jtd dynamic and am looking at fitting a 6 button wheel
jonathanbees is offline Reply With Quote Quote
Old 21-06-2012   #5
Stilo Passionate
andreist31's Avatar
Quote Originally Posted by jonathanbees View Post
Short, yes it is the same.
As long as the steering wheel has buttons it doesn't matter how many it had, all the clocksprings are the same, 6 or 12 buttons. The buttons work via CAN network so it doesn't matter how many buttons are there, the clockspring has the same connector.
Hope I was clear enough,
Andy
Old 01-07-2012   #6
thanks very much for your help one last question
there are a couple of steering wheels one with just stereo buttons on and another with loads of extra buttons on for the connect nav my car has just got the standard vision stereo so will the wheel with all the extra buttons on for the phone/connect nav still work ok
thanks jon
Old 14-07-2012   #7
grate advise works really well thanks
Old 06-03-2013   #8
Romania
Thank you very much for this guide.
So what i need is 3 wires, and i connect this from navi directly to the springclock? That is all?
I am a bit confused about the can connections..Are not controlled by the ecu?
RainMan1 is offline Reply With Quote Quote
Old 02-05-2013   #9
by fitting this does proxy alignment need doing as millage has been flashing since
Old 03-05-2013   #10
Stilo Passionate
andreist31's Avatar
Yep, proxy alignment will be needed after this as you are basically adding a new node on the CAN bus.
@RainMan1
Sorry for the delay in the reply, have been away for a while. Yes the 3 wires is all you need. The can connections are controlled by the ECU, but you can add new nodes on the can bus (as long as the ECU will recognise them, i.e.: the steering wheel buttons, rear electric windows, etc). This is what the 3 wires are doing, connecting the steering wheel buttons as a new node onto the CAN bus.
Andy
Old 22-01-2016   #11
Netherlands
I have a question. My clock spring is a little differrent than yours. What should I do?
Bariky is offline Reply With Quote Quote
Old 22-01-2016   #12
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by Bariky View Post
Hi, Welcome to the FF.
As stated on the first page of the guide, you will need "A clock spring from a car that had buttons on the steering wheel"
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 22-01-2016   #13
Netherlands
Quote Originally Posted by Davren View Post
I do have one that supports a steering wheel with buttons
Old 22-01-2016   #14
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
What is different about it?
Comment
Guide Tools
(T) Steering Wheel Buttons gsxr6OO Grande Punto 9 07-08-2010 03:51
(G) steering wheel retrofit? pondweed Panda 2 30-11-2009 07:33
(G) Steering wheel buttons Matkap Bravo 8 16-08-2009 14:05
(T) Steering wheel buttons leegar30 Panda 9 01-02-2009 03:29
(T) Retrofit Leather steering wheel w/controls?? reinventingyourexit Stilo 15 19-05-2007 18:27
