- Joined
- Nov 11, 2019
- Messages
- 81
- Points
- 64
Hi All,
Ive been experiencing some issues while trying to set the timing on my ‘09 100hp.
The cam belt failed and valves bent. Ive had the head reconditioned with new and skimmed at the engineers. After reassembly and following the elearn guide to set the timing the engine won’t rotate. My question is this. After the head is skimmed do you need to use a shim plate or thicker gasket? I had a mechanic friend come out and check my work but he did pretty much what I had already done for the same outcome. Insights and help are much needed!!
TIA!
TIA!
