'BTW how did you manage to put the D/S bearing on the wrong way round and what effect did it have? as it may help when doing it next'
Alan, the kit came with the seal/bears ass. in position inside the boot, but my mate (a full time mechanic - vice free and circlip pliers!) said he normally doesn't bother to swap the seal/bearing ass.) and separated the 2 - he was busy - I got distracted...
..took for ever to tap it on wrong way round as I hadn't got the recommended length of tube either!
Later when I put the d/s back on and realised the bearing was visible the effect was:
:bang:
Ground down some old long nose pliers to get circlip off and found some 1" copper tube which I cut lengthways into 2 halves to make collets to fit inside the recess on the bearing so I was able to tap it off again (with mole grips loose around d/s acting against copper collets)... otherwise I would have had to go and get another boot kit...
second time I didn't set it up to the collar (the end of machined section on d/s) either just to the rec. 143mm - which (presumably) stresses the boot less... anyway job was a good un in the end
I once got distracted by a neighbour when fitting a balljoint into a Uno lower susp' arm - put it in upside down! - by the time I'd pressed it out and in again it was too loose - had to go and buy the complete arm then... doh...
It poured with rain again as I refitted the driveshaft (soaked again!) but otherwise it would have been a straightfwd job. Next time though i'll def. give a bit more thought to the rec. tube fitting tool as outlined in the Haynes manual as the bearing needs to pressed on very close to the d/s with no force applied to the outer parts of the ass. Kit was non Fiat and about £17 btw
the only other prob encountered was with one of the gaiter clips - with restraightening it fractured - but I was able shorten and reuse it
cheers
