General  eco tek power boost?
Milton Keynes
Hi guys
I was just wondering if any of you guys have used the eco tek power boost or any other sort of additives or octane boosters? the eco tek power boost is suppose to give your engine more power, crisper acceleration and clean your engine too! my better judgement tells me that you cant buy that in a can, can you?
Products like these can make a difference sometimes. Just remember that if you have a high-mileage engine then some of the crap might be filling gaps that you want to be kept filled!
Hello
Just recently fitted the ecotek (not the boost but the actual device) to my 60sx. Only had it on a week and i have seen a big improvment in fuel eco and also the car picks up quicker
My car has done 70,000 and runs excellent but this little device has made a difference, well worth it!
Mk1 60sx, full Abarth kit,lwrd40mm, 16 momo sport,
Ghost - Are you talking about the Ecotek Valve? If so, I think this is about the Ecotek boost spray (cleans engine via the air intake....)
Incidentally, I've got the ecotek on my MK2 8v and it's great IMO.
supermcc_afc said:
Hi guys
Ive used the Nitrox power boost (I think) Its supposed to do all the nice things to the engine but I cant remember noticing any performance changes. The Ecotek power boost spray goes directly into the engine so I would think make a noticable difference- only a presumption though ;) If you've got an older engine its probably worth a go (y)
To apply it do you have to take the airfilter off, or spray it into the airfilter whilst reving :confused:
ad2510 said:
Hello
no, remove it unless you have fitted it centrally (i doubt it) I contaced ecotek about fitting it on the FIRE units and they confirmed what i thought.
If you fit it on the brake vacuum line, it will only effect airflow to the no4 cylinder this will result in the mixture to no4 being leaned off. this is not good. for the ecotek to work, you will have to drill and tap the inlet manifold in a central posistion, ie below the throttle body and fit it there.
this is the same for any fiat 1108, or 1242 8v engine (actually, the 75 may have a slightly different inlet manifold, but i dont know)
have a read through here:
https://www.fiatforum.com/showthread.php?t=4315&page=2&highlight=ecotek
the cinq sporting uses essentailly the same engine
Well I had the Ecotek on my Rover 416 sli which was fitted to the servo vacuum hose. I did the same thing on the MK2 Punto (after seeing how it would perform on the Fuel hose first like Wolfrace) and it reacts in exactly the same way as it did on the Rover.
If anyone says that this shouldn't be done then I'd be keen to hear it.
wolfracepunto said:
I was actually told by one of the moderators of the Ecotek forum that it would be fine to fit the valve in the brake vacuum hose (Not the fuel line :rolleyes: lol) Surely they're not going to give out false information :confused:
he doesnt know the design of the engine, or how the inlet manifold looks inside. I do, and contacted Ecotek directly about it, and they said do not fit it on the brake servo line
I told you when you fitted it, i'm sure. What will happen? It will lean off the mixture for the no4 cylinder only. leaner mixture = hotter. Also, the lambda will read too much o2 in the exhaust and the ECU will increase fueling.
Thats why the ecotek is pointless on modern engines, the ECU just compensates for the extra air the ecotek provides
I think the 75 takes it vacuum for the brake servo from the no4 pot end, but given the 75 is a 4 injector system - with injectors in the flow line of each chamber, the effects might be worse...
Personally I wouldnt bother, I had one on my 899cc Cinq (that took its vacuum just downstream of the SPi module) and it made such a little difference, its sat in my desk now!!
I'll just close it off for now as I'll need to repair the brake servo hose otherwise.
When it's closed it's basically as if it's not there anyway - allows the air to flow through (but not out of the valve).
Octane boost will generally give best results in high compression engines it probably wont improve performance much in a road going engine, It can also be used if the car is suffering from "pinking"
