doctorpunto
Hello, I've recently bought a fiat punto gt2 and i'm having trouble with it.
When the engine is dead cold the engine will start and idle fine for about 2 mins. Once it starts to warm up the idle goes lumpy. However if you rev it above 2000rpm the engine smooths out.
The misfire occurs at idle or sub 2000rpm when the engine has warmed. Just fully serviced and the plugs, Leads, and coil pack have all been changed and I recently changed the knock and tps sensor with no avail.
I've checked all the vacuum hoses for breaks etc but all seem ok.
Any help or advice much appreciated.
