jdunderhill
This is my first ever post!!
I've bought some new led washer jets and having no end of problems fitting them!...
I've tried and tried to remove the washer jets from my Punto 60 SX but no luck
I can see the tubing which I can pull off the two jets, that then leaves another plastic connector, I just can't see how to take off the jets themselves, do I need a special tool?
They are very difficult to get to any help would really be appreciated from anyone that has ever fitted them
It's hard to describe but with the bonnet up and looking at the jets I can see a plastic connector which is about 3-4 cm long that fits directly to a jet when I twist that I can't release the washer jet, so ther must be a nut holding the jet in place but I can't see it!
Any ideas how to hook the LED to the headlight would help (Black wire goes to ground, red to a front headlight)
Thanks in advance
Jamie
Thanks in advance
Jamie
