What's the Weber Marelli reference on the ECU?
Time to get to the bottom of this!
The 1.6 sporting engine has a GM ecu, same as some random old corsa but the diagnostics side of it is different so i have read. This is why none of us have really got much experience with them, from what i have read online because the diagnostics port is different and some things have been changed in it from when it was in the GM cars you can't use the programs that the corsa people used - although of course that might not be true and they will work as i have never tried it...... It maybe possible to use whatever they use (searching an appropriate forum should find that out) and ye olde fiat 3pin to OBD & OBD to USB adaptors. But cannot be sure.
attached is a pic of an ecu from a 1.6 sporting, you can just about make out all the numbers and stuff from it.
