Joes punto
see below for picture, seems like a pipe is missing any advice on whether it is necessary or where i can get a replacement, thanks
I had one on a BL Mini. It made absolutely no difference.
Maybe in very cold conditions it reduces carb (throttle body) icing but otherwise I dont think its needed. The Punto throttle body is already heated so icing should not be an issue anyway.
Isn't there two small hoses going from the cooling system to the throttle body?
Warm air usually means more fuel used as the air is less dense so carries less oxygen.
With warm air tho - surly less oxygen = Less fuel needed to Burn at correct mixture
So Surly in winter - a Hot air feed is better?
ziggy
